Laser Cut And Fill
The Laser Module is available as a paid-for add-on to the software. The features are not included in your software by deafult. To find out more about the Laser Module go to https://vectric.com/laser-module
Tool Selection
Select Tool
Power
Move Speed
No. Passes
Strategy
Based on the selected vector shapes in your drawing, this toolpath offers four distinct strategies.
Cut Outside / Right
Cut Inside / Left
Cut On
This option will run the center of the laser beam along the selected vector. No offsetting or kerf compensation is required.
Hatch Fill
Allowance
Stepover
Hatch Angle
Cross Hatch
Checking this option will create a cross hatch fill instead of a single set of lines.
Immediate Output
Post Processor
Add side to toolpath name
Output direct to machine
